Qwerty03
Miembro 720p
- 14 Noviembre 2022
ZIDOO CONTINUOUS EVOLUTION The new 2023 Zidoo products represent a natural evolution of the previous 1619DR generation. They gain an appreciable performance boost, HDMI 2.1, more RAM/storage across the range, Android 11, Bluetooth 5.2, WiFi 6 and AV1/HEVC codecs. What stays the same is Zidoo's best possible picture quality, excellent media management software, rock solid commitment to firmware support and outstanding hardware quality.
NEW 2023 VERSION SPECIALIST MEDIA CHIPSET Realtek RTD1619BPD chipset designed specifically for media playback and audio/video quality. Faster performance than the previous generation with higher CPU clock, larger CPU bus and updated GPU.
DOLBY VISION MEL+FEL Supports for all Dolby Vision profiles (4, 5, 6, 7, 8 all levels) including dual layer profiles 4 and 7 using the base layer + RPU. Specific format support includes P7 BD-ISO/MKV/MP4 MEL&FEL, P4 MKV/MP4 MEL&FEL, P5 MKV/MP4 and P8 in MKV/MP4. In addition to Dolby Vision Direct and Dolby Vision LLDV, Dolby's VS10 HDR processing engine can improve dynamic range for all HDR material.
HDR10+ / HLG / HDR HDR10+ dynamic metadata processing with accurate HDR10 metadata (MaxFall, MaxCll). Support for HLG and regular HDR10.
HDMI 2.1 4K 60Hz output (HDR10/HLG/HDR10+/Dolby Vision). 12Bit, BT.2020 wide color range and YCbCr 4:4:4 colour space.
4GB RAM & 32GB STORAGE 4GB high specification DDR4 RAM. 32GB onboard eMMC storage.
https://www.futeko.com/products/MP130.php
